mx1500
how could i or can i even remove the rev limiter or adjust it so when i pin it over a ditch and the track is off the ground it sounds very weird. can i take this off or not. thanks
fraolib
u want to eliminate your rev limiter???? i almost never hit mine. u know its there to prevent any motor damage rite....... and if u think the rev limiter sounds weird your really gonna dislike the noise the motor makes when it detinates
mx1500
okay. well with the tuned pipe on it is annoying for the split second that its on
RedPhazer
The best course of action would be to adjust your clutching so that you don't hit the rev limiter. The Ulmer kit would be a good place to start. You should never rev past 11,500 rpms...
mx1500
going down the field flat out its about 11,000rpm
fraolib
i had a worn belt on for a few days and it was revin 12400 and never hit rev limiter.......
mx1500
after my 2 years ive never touched the clutch or belt. its been great.
ThatOneGuy
fraolib said:i had a worn belt on for a few days and it was revin 12400 and never hit rev limiter.......
It seemed like mine would start kicking in at 12300, 12400 would be the most I would see and it would be stuttering from the limiter
Joe
