revalve question
Well I got my revalved shock in and wow does it feel different just bouncing around on it in the garage. It will definitely be harder to bottom - no doubt. I also noticed that the RA seems to have a much more drastic affect. You can feel a big difference in the RA settings just bouncing on it. Soft is soft (fast rebound) and hard is like a brick.
As for the set-in I found that I still needed #7 on the second C clip to get 40mm set-in. That's the same setting I used before but suspect I was probably over the 40-45mm before the revalve. Can't wait to get some snow!
