alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
hit the reverse button and always stay on ,the sw did,nt want to forward I don't know where to looking for.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Does it click, do you hear any noises when you try to switch, does the backup alarm go off, have you checked fuses, relays?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Are you saying it’s stuck in reverse?hit the reverse button and always stay on ,the sw did,nt want to forward I don't know where to looking for.
alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
No noise and the backup alarm stay on.haven't check fuses yet.tomorrow morning will do
alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
YesAre you saying it’s stuck in reverse?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Two shift relays under hood up front.
One for forward and one for reverse.
I had a bad forward relay in the past and was stuck in reverse.
Pull the relays out and they are labeled underneath them.
Mototown
- Sep 11, 2018
- Apex 40 th
If you want to ride tomorrow take reverse servo motor off chain case , with motor off slide tooth spline above hole to left with someone rocking secondary back and forth will get you to drive.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
New '23? There is an issues with some of them...
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Your upper gear bushing cold be toast
alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
brand- new.i will check relays this morningYour upper gear bushing cold be toast
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Relays and the shift fuse which is the only 25 amp fuse (bottom, second row). And the connector to the switch actuator.
I would pull the right panel off and have someone listen to the actuator as the button is pushed. Check the harness there. The Shift Forward and Shift Reverse relays are identical and can be swapped.
alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
That was the shift fuse.Thanks all for the reply.
