Reverse chain
allyammies
Darien Wi
How loose is reverse chain? Seems a little too loose but not sure. This is on a 14 viper.
Well all back together. Little leak on the damn thing but can live with that for now. On decel the chaincase side bearing howls a bit. Chain too tight or too loose?
Well I guess I will pull exhaust off again and loosen a bit. I did do a turn and a half so not sure why it howls on decel.
Regarding your leak, you may want to consider this superseded seal as the better option. It is @.026" thicker than original. I replaced my 2015 viper seal with this and have eliminated the slow leak issue.
img_1729-jpg.141568
