CrankyApeX
- Oct 5, 2007
- Woodbury, MN
- www.crankyape.com
So does it ride as good as it looks?
I have been having lots of problems keeping the throttle bodys on from the boost and then the pully on the sled to run the Super Charger... when it works its fun...LOL
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
You need to grind the spacers on the clamps down half way. I had trouble blowing mine off till i did this. i blowed them off once since and when i put them back on i sprayed hairspray on them and so far so good.
welterracer
Tom
What kind of rubber boots do you have.. I have had the silicone boots on my camaro and had tons of problems.. if you get the thick black rubber boots they work alot better (but about 4 times the cost)
The silicone boots are garbage.. they expand and are slippery and slide right off..
Ive heard of people super gluing them on.. also make sure and use good T bolt clamps if you are not already..
I know I need to get the time to get in there I have several ideas... thanks guys.
Hmm I wonder if I will see this sled in person next week...... WIll I? I hope so Thomas.
I will have it there... doing some things on Sunday.
FLYBYU
you need to get 3 3mm washers for each clamp
Explain??
FLYBYU
You need to take the factory spacer out of the clamp and put in it's place 3 3mm washers
thanks
FLYBYU
not a problem Tom. see you in muni
FLYBYU
how did it work Tom?
for now I have not tied into that I have another temp fix to get it thru the season... time is tough right now.
