yamaslob
Ripped the seat on my Nytro what should i use to fix it, its only about a 2inch scratch the dealer put some bondo stuff on it not doing the job.
Thank you
-James
Thank you
-James
ecopter
This stuff works great. I believe you can get it at Lowes or a similar store.
Jon
http://www.tapplastics.com/shop/product.php?pid=288
Jon
yamaslob
Awsome is there any way to cover up the color of the bondo with a silver paint?
ecopter
Will the 'bondo' stuff come off? If it does, the VLP will dry clear and is extremely flexible. If it doesn't come off, Rich Freeman (richmotorsports) may have ideas on painting vinyl.
Jon
Jon
yamaslob
Alrite thank you ecopter.
nobody
The only real fix is to get a new one! maybe ebay?
Indy
I would have doubts if the tube stuff would hold up. If not just take the seat off and take it to an upholsterer. They could sew in a small panel replacement for a few dollars. Much less than a new seat.
yamaslob
Indy said:I would have doubts if the tube stuff would hold up. If not just take the seat off and take it to an upholsterer. They could sew in a small panel replacement for a few dollars. Much less than a new seat.
Exactly.
rxmaninblack
Permatex makes a patch kit that comes with different colors of paste to mix into the patch. I have bought this at NAPA to fix 2 different sled seats. Works very well. It even has different texture pads that you put onto the patch and heat with an iron to match the grain of the vynle (sp)
yamaslob
Ill go to NAPA today and check that out.
