Ripsaw 2 help
WINDER1987
Upstate NY
Hi guys I found a guy near me selling a 15"x121" 1.5" ripsaw 2 track that I'm thinking of buying question is will I have any rubbing issues if I stud it or will it put the studs to close to the heat exchanger ect ?
How would a 1.5" track compare to 1.25"?
X2 ^ I had issues running studs in the stock track rubbing on everything. Unless it's the xtx, they seems to have more clearance for some reason. I've had really good luck with my 1.5 ripsaw, tough as hell and hooks up better then when I had studs plus it's much better in powder.
You might double check with the guy, but I do not believe there is a 1.5" lug Ripsaw II yet. The original Ripsaw is still available in a 1.5" lug though.
