Rode my Rage this weekend
mikebeane
Massachusetts
First time out with Rage was great. Immediate response from throttle. 14 mpg on first tankful. I think it will be better after break-in. Top speed was 103 mph and will go alot faster. Reverse was a little tricky. Getting the lever into reverse. Then track was spinning. But overall, it's a ripper!
Hey Mike, if your reverse is tricky, shut the machine off. If it goes into reverse easily with the engine off, you just have a slightly tight belt. Either wait for it to wear a bit or shim the secondary. BTW, the Rage is a lot of fun. Great motor for trails and boondocking.
sometimes its pretty tricky, depending on how numb ur fingers r, but usually i just drive forward a couple of inches, but i understand that its not possible in some situations, but just keep playin with it and eventually u'll get it down
I've noticed on my V-max and the new vector if it won't go in reverse just move forward an inch or so.. Goes right in then.... ;)! MM.
