Question for Rage/Vector owners???
Rage 2005 Yamaha : The dealership could not confirm that the track is a camoplast as theowner is out with the flu. So far the track has been super on the harpack for hookup. I believe the hookup tends to push harder in the corners than the 1.25 but if you use the throttle it can be controlled rather easily. I am going to go with bergstrom skegs,skisavers and his shims to see if this will help to control the push in the corners. I will contact the dealer and confirm the manufacturer of the track. It looks like a ripsaw but iwill have him confirm it. :4STroke:
I use bergstrom with the shims and love them also the ski saver...as far as pushing in the corners...if its real icey I think most sleds push when its real slick especially if you use studs the front end will tend to slide thru the corners your only hope would be a very sharp carbide to help prevent that from happening.
Rage 2005 Yamaha : Just got off of the phone with my dealer. Yes the track is a camoplast. Took to the logging roads last night as we have 8 to 10 " of fresh powder . The track performed great. The only regret i have was not swapping the stock skiis for the 05 Mtn. skiis as the front dives if you let off the gas to much. Otherwise i love this sled. Head to Chassell to see the drags, supposed to be some RX Turbos there. Thanks for the info on bergstroms i will be ordering from him shortly. Happy sledding and again thank you for the info.
