northernguy10
are they worth it? my 06 attak is stock accept for a zx2 rear skid. could I get some pro/cons from people who have it .
northernguy10
nobody's got a roller secondary? with imput.
irondog rtx
I got a team roller on both apex 06 rtx & apex atack they work great I like better than stock also have t spring hope this helps and a new tied roller coming from whal brothers Kim
Dano
I have the roller rooster and also tried other roller kits.
Pros- better back shift qualities and better shifting with fluctuating speeds.
- never need to worry about wore out plastic cam slider shoes
Cons- More expensive and less popular helixes for experimenting.
- Don't seem to get as good top end speed with them.
I'm currently running a slightly modded stock setup in my Apex and find it the best.
Dan
Dan
fireman1069
The stock secondary on my attack is actually set up very well from factory. Not to say that it can't get more refined and a roller would do just that. Where I think you will gain is faster backshifting and probably better response coming out of the corners. You may have to fine tune it to your taste which is really not that difficult. Is it worth it? I think it is. I put a HC-X on my sx 700R with triple pipes and it was one of the best mods I put on it. It works very well and is a hoot to ride. All that power is worthless unless you can put it to the snow. I am in the process of putting a billet rigid roller secondary from super torquer on my attak and am excited to see the results.
- 6K
