rough idle and slight miss
stephen03rx1
winnipeg,MB
Hi guys, I have a 2004 rx1 all stock and am having trouble with it idleing. What happend was my heated face sheild cord melted on me during a ride and it blew my acc fuse. After that my sled has not idled right . It has a slight stumble at idle and all four of the plugs turned white. I have tried another set of carbs from a buddies sled, i have changed the plugs and coils , i have tried a different cdi , i have checked compression, i have tested my tps ,cleaned my tors and synced my carbs still no luck. The weird thing is if i disconect my coolant temp sensor the plugs will go black . So i am guessing that the cdi goes in to a limp mode to protect the engine . Any help will be great guys . thanks
I did check the stater and it all tests fine . However i did just adjust the tps but have not had a chance to try it yet . The tps was reading to high of voltage whitch would advaced the timming . Ill let you guys know after i try it .
Back again. So i tested the sled and still does not idle right . All four plugs are white and when i do a full throttle run and let off then get on it hard again it stumbls really bad . This sled never did this before the electrical short. Im thinking the timming is out still. Anybody? please help
So nobody has any sugestions ? Any ways i have swaped out every electrical part with a buddies sled and still iddles rough . The next step im going to do is change he wirring harness as this never did this before the electrical short. Ill let you guys know in about a week when i get my new harness from ebay. since nobody has advice maybe i can help the next guy. Thanks
I had some similar issues in the past. This year I went nuts in the pre season and don't know what really did the trick but my sled has never been better.
1. Ran the sled up to temp a few times and sprayed aerosol seafoam into the carbs like you would on a carbed car to help clean valves ect.
2. ran sea foam in the oil for a short time to clean rings kinda like a shock treatment of ring free.
3. then chained the oil and pulled the carbs for a serious cleaning. also I recommend when cleaning to make sure you clean the pilot jets with a touch tip cleaner or wire they are so small they may look clean but might not be.
4. changed the plugs and went back to stock as my sled did not like the cooler ngk 10's people run.
5. dissembled the coils or plug caps and cleaned and greased with dialectic
6. last and possibly the most important was I bought a sync tool and did the carbs it was well needed they were all over the place should have done this years ago.
good luck I would be looking at your plug caps or coils and maybe a sync?
So as for the cleaning of the carbs. I have done so 9 time and I'm not kidding when I say 9. Still the same. I have tried a buddies set of carbs wich work great on his stll runs the same. I put mine on his and it runs great. I just swapped out the harness with a spare and still plugs are white. When I say white I dont mean just one I mean all are white. It has to be a timming issue. My next step is to pull the stater and try buddies. I love my rx1 but really , I think this thing may make me nuts.
Sorry and another reaon I think it is timming is that right after the short my sled was pulling 11000 rpm at wot and right before that it was pulling 10200 at wot witch it always did prior. I know alittle bit advanced is ok but mine is at the extrem. Just a little food for thought. Thanks again guys hope some one can throw some more ideas my way.
All right so I swapped out the stator still the same. Did a compression test 212psi across the board. I did a leak down test tured out good. So next step again is to try a third cdi box and see what happens. Hope to get me hands on one this week. Ill post again after this weekend when I try it.
Thanks JDP1under. I will try all of the following. I do have a brand new sync tool on hand and like your sled mine dosent like the cr10ek. I only have 500 miles on this year and hope to put 500 more on before the end. Ill let you know how it turns out. Thanks
Sounds like you are running lean and hot if your plugs are white
I would check Fuel preasure...... Fuel filters
-possible air box leak
What plugs are you running and what gap?
Barry
