ROX Anti Vibration
runzonmt
09 RS Venture GT has anybody installed 2 inch Rox elite anti-vibration riser. I like to know if the cable need to lengthen dosen't seem to be much play.
Normally you can go 2" no problem.If you find it tight.Check how the cables are running down handle bars and thru the gold metal hoop.Arrange them so they are closer to the throttle side etc. and you should have enough play.
I have a ROX 2" pivoting riser so I'm not sure if it's the same height but it fits barely. I had to remove the gold cable holder to get enough slack in it so it didn't keep activating the TORS on tight corners. With this setup there is only a turn of adjustment in the cable where the sweet spot is..
Installed riser had to adjust throttle cable free play and rearrange some couplers no more vibration. LaLaLa
