turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
I think my attak is turning a bit too high. I have stock clutching and a new belt with about 300 miles (first 200 were gentle miles) I am hitting 11,000 or just slightly under on the trail when I hit it. What is the target Rpm? (10,600-10,800???) What should I do to bring it down? I looked at the helix and sliders and they look good and is in No.3 on the outter hole, didn't take it apart to look at the inner.
Capt.Storm
Tachs can be off ..you're prolly fine.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Ya I know tachs can off but it was turning 10,700 0r 10,800 last year. how would I bring it down slightly?
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
try replacing your primary spring, could be wore
kuvasz
change the setting on the secondary spring. if you change the setting to 6 or 9 it'll drop the rpm's by 200rpm each. i always run my sled at 10,800. big difference in power from 10,400 to 10,800. apex's make all their power at 10,800 and all their torque at 10,200.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Thanks kuvasz.
Hey blevis213, wouldn't installing a new front spring have an opposite effect?
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Is 6 or 9 more tension or less? I would be looking for less correct?
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Any Clutching guru out there?
If your sled is starting to over rev for no apparent reason I would suggest trying a new belt.
The degrees of secondary spring wrap is the sum of the spring position hole in the clutch added to the spring hole position in the helix x 10.
For ex: spring end in number 3 hole in clutch
spring end in number 3 hole in helix
3 + 3 = 6 x 10 = 60 degrees spring wrap
The less degrees of spring wrap the lower the rpm.
On the Yamaha secondaries I would not run under 60 degrees of wrap, if your RPM is still too high you may have to change your primary spring to a lesser final spring tension.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Clean your clutches.
Scotchbrite your belt with soap & water.
Check Spring in secondary to make sure it is in the correct holes.
If those don't work, change the belt.
If that doesn't work add another gram [bigger rivet] in the tip of the primary weights.
Tuning RPM by decreasing secondary spring pressure is a band aid fix. It will slow your backshift.
