yammi
So which route first, OSO spring or tip weight?
Skydog
Do you want your engagement higher? If so put in the spring. If not take some weight off.
I like to run soft springs my self.
Skydog
Skydog
yammi
I think I follow you. I'd rather have a lower engagement, so if I put in the OSO, which I don't believe to be stock on my Warrior, I should get a lower engagement and the top end should rise a bit with final tweaking, if necessary, through the tip weight. Does this sound right?Skydog said:Do you want your engagement higher? If so put in the spring. If not take some weight off.
Skydog
Skydog
No the stiffer spring will rasie engagement and shift out speed. (will rasie rpm every where)
Taking tip weight off will mostly just rasie your full shift out rate. (about 100 rpm per gram)
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
In my 04 Warrior with the OSO spring, engagement is about 4000 RPM and the RPM goes to 10400-10600, along with the shimmed secondary I saw 123 MPH on the DM. 8)
yammi
I assume you have a stock clutch set up?Bob Miller said:In my 04 Warrior with the OSO spring, engagement is about 4000 RPM and the RPM goes to 10400-10600, along with the shimmed secondary I saw 123 MPH on the DM. 8)
Bob Miller
- Apr 19, 2003
- New Milford CT
yammi said:I assume you have a stock clutch set up?Bob Miller said:In my 04 Warrior with the OSO spring, engagement is about 4000 RPM and the RPM goes to 10400-10600, along with the shimmed secondary I saw 123 MPH on the DM. 8)
Yes! I was also running SLP anti-Wear Pads, and Green Holtzman Carb Springs and the (Hotter Spark Plugs) NGK 10 ?
This year I'm adding a Silver Secondary Spring, 14.5 mm rollers in the primary, 4 TPI Valves and 160 main jets!
