This a sticky thread that each section can use to post thread links and info on mods, tech questions and How to?. Please do not use this thread other then helping others find what important about each model. All other post that I find in this area that are not of any use will be removed.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Ok I need a quick how to clean the carbs, pilot and main on an 05 vector. Do you need to pull the carbs or can you just pull the airbox and clean them from there??? May sound bad but I'm sick of the trailer to the dealer thing, I'd rather do it myself.
Groomerdriver
RSVECTORFREAK said:Ok I need a quick how to clean the carbs, pilot and main on an 05 vector. Do you need to pull the carbs or can you just pull the airbox and clean them from there??? May sound bad but I'm sick of the trailer to the dealer thing, I'd rather do it myself.
Good post Freak - I'd like to learn also! Also - will we need a synch tool to do the job right?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Well the carbs have to come off thats for sure after looking at the carb diagram but how to clean them is the next question.
phat bstard
- Nov 21, 2007
- South East Georgian Bay Ontario
rs venture suspension upgrades
I own a 06 rs venture and I wanted to upgrade my front and rear suspention to create a factory Yamaha 144 machine that could carry lots of gear and fuel into remote areas of Canada at a high rate of speed while competing against 29 other teams. Thru Totally Yamaha and its following I was able to start this process. It went like this. I used portyamaha fishe to source part #s for alternate springs for rear of rear(only springs I could source) Then I had 08 venture GT alluminum body rebuildables revalved to a more euro spec. (stiffer) For the front end I took some stock attak soqi rebuldables and added tunable remote resevors that I can adjust both high and low speed dampening and had them revalved to a stiffer spec. I did not install a stiffer sway bar yet as I am mainly in a straight track for extended periods of time. I will post pics of this sled as soon as my rear fuel tank and storage is complete. It is real ugly.
PB
PB
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Front bushing replacement. The example is an Apex but lots of the steps apply to the RX/RS series as well.
Front Suspension bushing replacement
vector jockey
- Nov 29, 2016
- Utah
- Yamaha Vector RS90MKS
I have an 05 Vector that would not start after sitting all summer and figured it was probably a gas/carb issue. I found this link with a step by step to remove the carbs and clean the jets. I followed the steps, cleaned then re-installed the carbs, removed last years gas and replaced with fresh non-ethanol 87 octane and after a little sputtering it fired right up. Not bad for a non-mechanic. Here is the link: http://www.totallyamaha.com/snowmob...Carb Cleaning/Carb cleaning 101 with pics.htm. I did make one mistake that is creating some heartburn and I need some help with. When I disconnected the coolant line from the carbs I didn't do a good enough job clamping this line off and emptied the coolant reservoir now I am trying to find some info about bleeding the air out of the system. Any help here would be greatly appreciated.
RS Vector
Dead Dash Display
http://ty4stroke.com/threads/dash-digital-display-not-working-on-2012-rs-vector.148745/
Dead Dash Display
RS Vector
Dead Dash Display
I will add that.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Wags
- Dec 8, 2015
- Chicago
- 2008 RS Venture GT
2008 Venture Lite
phat-bstard
Let's see pic's of that Venture....
YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
I have an 06 Venture that I am in the process of changing the Stator. --here is the link I posted tonight looking for any help at all--thanks : https://ty4stroke.com/threads/how-get-stator-out-of-06-rs-venture.164564/ I am stuck at the point I need to get the Stator out and the spot is not large enough?
