dan wilson
- Jan 20, 2009
good morning!I pulled my skid out to go thru it,should have taken photo,s of it,does anyone have photos or a drawing how it should go back together right,I got it back in and it is binding and not working right,looks right,but something is up,any help,looking for shop manual or something that shows the rear suspention,getting a little irritated with it.2006 nytro with ck suspention
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Should be relatively easy for you but, it takes two people to reinstall the way we do it. Before placing the skid in, unhook the torsion springs and let the suspension collapse. Push the suspension toward the front of the track and center the suspension into the track clips . Then lift the front suspension up and screw in the front bolts . Then go to the rear of the suspension and lift it up and screw in the rear bolts. Then...reattach the torsion springs by rolling forward the plastic loops and then flip the plastic loops back. The rear of the sled should be off the ground. We use a regular jack stand to do al of this.
dan wilson
- Jan 20, 2009
I can get them in by myself,looking for a diagram on the ck chassis,or photo's of the 2006 nytro rear suspention
Go to the US Yamaha website, where you order parts, type in your sled, year, and area of sled you are looking for, it should put up a diagram of the rear skid to order parts from. Go through diagram to see how the rear skid assembly is put together, you can zoom in on it.
