lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
hello need a little help.
i lost center cylinder. engine runs real rough. i thought is was a plug but not the case. moving on replaced plugs no luck. moving on replaced coil boot that didn't work .doesn't appears to be blown up cylinder still has life left appears to be electrical what would be my next step.thanks for your help.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Have you swapped coils to see if the miss moved with the coil or stayed with that cylinder
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
i did not.
didn't realize each coil had a cylinder #
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
the electrical plugs cannot reach any other spots so its not possible to have messed up location
josnow
- Dec 12, 2014
- CMass
- 2005 Rage
I think what yamajon was suggesting is switching center coil with either of the other coils to see if the dead cylinder changes then you know it’s the coil
Is the center cylinder getting fuel?
Metallicat
Can you pull the plug to see if it has spark when you crank it over?
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
(update) i do have spark in center cylinder. but no fuel. plug is dry. i removed carbs cleaned out bowls all looks good reinstalled and same #*$&@ im at a lose. any suggestions are appreciated.
Metallicat
The fuel pumps went bad on my sled and starved a cylinder. I bought 2 from Barn of Parts for $30. That solved my problem.
And the center carb bowl was full of fuel when you removed the carbs?(update) i do have spark in center cylinder. but no fuel. plug is dry. i removed carbs cleaned out bowls all looks good reinstalled and same #*$&@ im at a lose. any suggestions are appreciated.
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
thank you metallicat lol like that name. i will start there
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
yes center bowl was full when i pulled the carbs . and after i started it up and ran it i loosened the bottom bowl screw it had filled up with fuel. im not sure why fuel isn't moving on from there
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
Does it run on three cylinders with choke on?
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
middle cylinder is not firing with our without the chock. waiting on two new fuel pumps to show up. hope that works already missed a trip this weekend.
swedishrider
- Jan 22, 2018
- Norrland
- Sweden
- Rs Rage, srv, a bunch of arctic cat vintage sleds.
Have you try gravityfeed the middle cylinder, if its a fuel problem that will tell you for sure.
Even if you have spark its not ceartian it will under compression.
Compression? Is there compression in the middle cylinder. (Broken valve or other mecanical problem)
