Jukka H.
- Dec 4, 2020
- Oulu, Finland
- Other
- Yamaha RS Vector -07
I have issues with Vector during idle. Got first symptoms just before season ended last spring. Vector just stalls every now and then even warm, I got a tip that I should change starter solenoid/relay... it is now done and engine not yet stalled, but there are still some engine cuts during idle. I have done some maintenance, changed donuts, cleaned gas tank, changed gas filters to new ones (inline), tank filled with new gas, cleaned carbs + synchronized, changed started solenoid/relay, new plugs, checked wiring and groundings and those cleaned.
I will do again carb cleaning this might be the case, but any tips if I should check something else would be appreciated
Made demo video during carb sync. Engine cuts at 0:23, 1,:10 and 1:43
https://photos.app.goo.gl/AAxfkeTEWwtVZRN48
