gamemaster
Do you have symptoms of a bad jackshaft bearing before it is to late? How easy do the shafts bend? Can a bent shaft be fixed? Thanks
why not just check it by popping a seal out with the clutch and snap ring off?
gamemaster
what am i looking for?
rust, dried up grease, broken bearing cage, discouloured (black or blue) cage rollers or races are some of the more common signs of failure. i wash mine out in place and repack using a needle greaser every year on my sleds.
gamemaster
ok, can shafts be saved if they are bent? thanks
depends how bad. i would not trust it myself if it was discouloured blue or black where the bearing runs on it.
