mikelikes4strokes
- Feb 7, 2023
- MICHIGAN
- RS VECTOR
Hi guys.
Anyone ever replaced a starter on a 2007 RS Vector? Can i get it out from the bottom without pulling the motor. Is there a video out there anywhere i can watch that you can point me towards?
Mike
Mike
Its a pain the aZZ and it can be done if you roll the engine forward in the front mounts. I dont have instructions or a video but I have done it..Hi guys.
Mike
wiharley02
- Dec 1, 2014
- Oshkosh/Neenah, WI
- 2006 Nytro, 2005 Vector
Mike, to my knowledge the 05-07 Vector (RS chassis) are the same. I've done it on a 2006. Do some searching on here and you should find other posts that explain in more detail. Yes it can be done without pulling the engine. If memory serves me correctly, pull the airbox and the battery/battery holder, pull the forward mount bolts and lift up the front of the engine (pivots on the rear mount bolts). Don't need to disconnect exhaust pipes, the flex couplings have enough give. Remove oil filter for more access from below. Starter will drop out the bottom of the chassis.
mikelikes4strokes
- Feb 7, 2023
- MICHIGAN
- RS VECTOR
hi guys
thanks for the info. your spot on with the instructions.
thanks again.
Mike
thanks again.
Mike
