saltr
- Oct 14, 2014
- RS Venture GT
Bought a used 2009 Venture GT last year. Did not have a tool kit with it. Did these sleds come with one?,not that you would ever need it. If so I may consider purchasing one. Thanks-saltr
they all usually come with one in the trunk of the sled.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
No tool kit that came with a sled was ever worth a crap.....at least to me.
Tools to change plugs, wear rods, zip ties, duck tape, new plugs, wire cutters.
saltr
- Oct 14, 2014
- RS Venture GT
THANKS!
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Tool kit should be located by the belt guard.
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
at the very least a crescent wrench in 2 different sizes, multi screw driver, extra washers 8/10/14mm nuts and bolts, gas line anti freeze, siphone hose, and a belt from a pair of pants (in case your starter goes)
also did you look in your seat storage for it?
saltr
- Oct 14, 2014
- RS Venture GT
Yes I did,thanks.at the very least a crescent wrench in 2 different sizes, multi screw driver, extra washers 8/10/14mm nuts and bolts, gas line anti freeze, siphone hose, and a belt from a pair of pants (in case your starter goes)
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
4, 5 and 6mm allen wrenches (preferable with a ball end)
Deepwell socket of correct size to remove wear rods
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
If you find the tool kit, which is relatively useless, it won't have a tool to adjust the coil springs. That is an optional tool.
A $15000 sled and a $3 wrench is an option, for $25!?
