RS Venture Tool Kit
saltr
Age
70
RS Venture GT
Bought a used 2009 Venture GT last year. Did not have a tool kit with it. Did these sleds come with one?,not that you would ever need it. If so I may consider purchasing one. Thanks-saltr
they all usually come with one in the trunk of the sled.
No tool kit that came with a sled was ever worth a crap.....at least to me.
Tools to change plugs, wear rods, zip ties, duck tape, new plugs, wire cutters.
at the very least a crescent wrench in 2 different sizes, multi screw driver, extra washers 8/10/14mm nuts and bolts, gas line anti freeze, siphone hose, and a belt from a pair of pants (in case your starter goes)
also did you look in your seat storage for it?
Yes I did,thanks.
4, 5 and 6mm allen wrenches (preferable with a ball end)
Deepwell socket of correct size to remove wear rods
If you find the tool kit, which is relatively useless, it won't have a tool to adjust the coil springs. That is an optional tool.
A $15000 sled and a $3 wrench is an option, for $25!?
