RippinV
well we were about 140 miles in today and the 2009 rtx in our group with 2500 miles on it shut down. oil in the belly pan, no visible oil leaks on top of the engine. was on a smoth trail, no damage under the sled, oil dripping onto the trail. tried to check the oil and the plastic plug is melted inside the oil tank. flashed code 11 on the dash and the sled wont start. towed it 42 miles to the next town for a truck. Anyone have any idea what^s going on with this thing
RippinV
took the beast to a local dealer here in mount valin and looks like a stud came out punctured the cooler and drained all the coolant. motor overheated really bad, the dummy riding the thing didnt realize the temp light was on, and the motor is cooked. YES is likely not going to cover this, anyone know how much it will be to rebuild this engine?
LazyBastard
If its cooked THAT bad... probably needs a whole new motor.
Check where the oil tank bolts on the bottom mine had a hairline crACK o both sides jb welded it and has been fine for miles!!!!!!!
