I have a 09 RTX and would like to by the rox/fly 4-5.75 inch adjustable riser. My question is will the stock cables be long enough with the riser extended to the 5.75 position? I believe the stock riser is 2.5" so it would only be like a 3.25 rise.
hey, just put an RSI extension on my sled. a 6" WITHOUT extensions. just re-roiute the throttle cable around the rad. youll figure it out once u see it. i put mine through a hole in my riser. works good
