RTX/RTX-SE/MTX Technical Question
stewartb
Anchorage, Alaska
I see a conflict between my service manual diagrams and the web-based Yamaha parts diagrams. My service manual shows a diagram of the center shock's remote canister being attached with a bracket to the inside of the rail but the Yamaha parts diagrams don't show that part. They show another type of bracket that suspends the canister in the center of the skid directly behind the center shock's lower mount. Web-based parts diagram availability isn't as complete as I'd hoped. I'm trying to locate a rail-mounted canister bracket and the associated hose holder that directs the reservoir hose over the inside idler wheel. Identifying an applicable model would be an excellent place to start. Can someone tell me if they have a canister that mounts to the rail and exactly what model sled you have? PLEASE?
Thanks,
SB
08 RTX. I have the rail mounted res. bracket. (port side) and hose guides.
Thank you. Apparently the parts diagrams are incorrect or mis-assigned. I'll be ordering some parts pronto. Thanks again for the reply.
SB
Anyone got a picture of a suspension showing the RTX front shock and resi mounted? Thanks..............
Pages 4-49, 4-50, and 4-51 in the service manual show the rail-mounted reservoir. Its not a sure thing that I can fit the reservoir into that location on an XTX if that's what your considering. It'll be very close because of the rear shock lower mount cross shaft. The SE mount is not applicable at all.
SB
