Does anyone make running board upgrades for the short track nytro? I have checked out the Mountain Tuff boards and Snow eliminators. They all seem to be made for the mtx or xtx. I was thinking of buying a set of the gytr tunnel reinforcements but i am not sure if these eliminate the snow build up or not. Thank you in advance.
bagadonitz
I've been looking too. I'm convinced the Mountain Tuff boards would fit. Is there really any difference between that part of the tunnel for example between an 08 RTX and an 08 MTX?
i called and spoke with someone at sled solutions today. The guy i talked to said the mountain tuff boards would not fit a regular fx nytro. I don't know why you couldn't make them fit though. The only thing i could think of would be differences in width.
Fasttoys
they are called better boards. call ulmer racing see if allen has some in stock for ya (1 605 387 2833)
did not know ulmer carried them. I will be calling them shortly. Thanks for your input.
Fasttoys
let us know how it works out. i need to get a set for my FX nytro
bagadonitz
The better boards look nice but I like the look, design, finish and price of the WRP ones better...
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
bagadonitz said:I've been looking too. I'm convinced the Mountain Tuff boards would fit. Is there really any difference between that part of the tunnel for example between an 08 RTX and an 08 MTX?
I am almost 100% positive that the boards will fit a 08-09 shorty, I tested a set for the XTX but the tunnel is different, my buddie took them home and checked to see if they would fit his 08 and said he couldn't say for sure since you have to remove the support to get them to side in, also they wont sit flush untill you cut out the old board so its a all or nothing attempt. I agree the MTX tunnel should be the same as the shorty till the extension.
Fasttoys
bagadonitz said:The better boards look nice but I like the look, design, finish and price of the WRP ones better...
i agree i think they look cool also. wish we could find out if they would fit an 08 short track
RocketmanROD
Just received a set of WRPS and they do not look like they will fit my 08 rtx without some mods. Will be trying tomorrow and can let you know. It looks like the reinforcement bracket is in the way!!
ROD
ROD
RocketmanROD
The length is too long for sure but as you said its all or nothing but not sure if I want to remove my stock braces if it will not work. I see noe that sled solutions has another set on there now for nytros???
Rod
Rod
Topgun
I used the sno eliminators on my shorty Nytro, they were awesome but needed just a slight trim near the back. Other then that , it was two years of good luck with them.
RocketmanROD
they look good
lukesju
Just installed a pair of the Yamaha competition tunnel stiffeners tonight on my 09 rtx se....they look awesome and I think an elephant could ride the sled without bending the rails. They were a little spendy but I figured it was worth the extra money. The install is a little much though....drilling 130 holes and then riveting 130 rivets! Thank god for the pneumatic rivet gun!
RocketmanROD
the stock stiffners are good i am trying to get rid of all the snow build up on the boards. The holes plug up and thats it. Always kicking the ice off.
