actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
This was definitely true with my Apexes. I can't believe they still do this. Change to 50/50 and no need for rear exchanger in my Attak. Guess I'm doing this with my Winder too.Yamaha usually runs a straight blend of antifreeze ,I would try to drain some of the fluid,add some purified water ,usually 75% AF,25 % water mix.Straight antifreeze retains the heat longer,the water mix will disperse the heat and allow better flow rate,also remember to let system purge and refill if needed.My new Apex and a few other new sleds I had had same symptom until I did the service and never had any issue ever after that,even in low snow conditions.Give it a shot,it worked for me.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Good luck with cable scratchers I got went through 3 sets of duraflex on my nytro in 2000miles they kept pulling the hooks off and this year just got a set of straight line performance for my BTX LE and guess what they look nice but the end ripped off with 300miles down on the trail and now I got new slides at 500miles cuz the one is shot! Back to normal scratchers just think when you back up.This was definitely true with my Apexes. I can't believe they still do this. Change to 50/50 and no need for rear exchanger in my Attak. Guess I'm doing this with my Winder too.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Had a mach z foul plugs once so used the headlight from my idling apex and after a while, it shut off by itself. Restarted with temp light on but it went off after some snow on the running board exchangers.
Heated up once last year with thin snow on a road for miles, so picked up the pace and the air from the track fanning the tunnel exchanger put the light out with no real snow....a friend got scared so I said go faster and his light went out too...on a vector. Dont like doing that, but they really weren't that hot.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Thanks Drant. I may try those. The flexible ones would hit my track & take some rubber off. I guess i should just slow down when scratchers are on, but then again maybe i should just slow down period. I plan on changing coolant after break-in & adding scratchers so just looking for all my options...
