I added a battery cutoff switch on my Viper as I upgraded the headlights with HID blubs and they draw power from the battery so the cutoff switch stopped the drain and a simple turn of the cutoff key and were good to go.I've had my battery on a tender while cleaning up my 2020 ltx se...its new to me and has only 300 miles on it. When i bought it the PO told me he put in a new battery due to something always drawing on it...obviously a "stink eye" moment. Fast forward to today and as I was hooking up the negative cable from the sled I saw a small spark...I haven't gotten into much yet but researching here shows a few known issues:
1. Worn wire under fuse box...already checked before and added thin foam to prevent an issue
2. Worn wire/harness on PTO side...checked and nothing noted
3. Reverse harness unplugged...this was apart but back together and OP had issue before
4. Gauge Cluster unplugged...its secure
5. Stuck Relays...have not checked
6. Bad Voltage Regulator from factory...have not started sled due clutches being off so I cant do a simple gauge check yet.
Any other things I missed or can cause an issue? your help is much appreciated!
MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
Sled is back together and got a chance to warm it up in the yard at least with a few inches of snow. Voltage showing on Guage cluster only showing 11.8-12.5 volts.
Most likely the voltage regulator. I'm going to pull it out and do the test that was posted. Any ideas besides that? Stator would be next I assume.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
It sounds like the regulator.
MyOutdoors
- May 4, 2003
- Lempster, NH
Did test and #'s are all over the place and showing bad...it looks like a few options are available. 1. OEM 2. SP1 Aftermarket or 3. RMStator Aftermarket. Pricing looks about equal on all 3. the OEM I just pulled out doesnt look like its sealed very well?It sounds like the regulator.
I usually like to stick with Yamaha OEM parts but having said that I have had good luck with RM stator parts as well.
This is on a sled with only 300kms?
If you look up the regulator it seems the number does change up...
This is sometimes a sign there was an issue with them.
www.cyclepartsnation.com
2020 Yamaha SIDEWINDER L TX GT (SW1NLGLR) Frame 1 | CyclePartsNation
Shop online for OEM Frame 1 parts that fit your 2020 Yamaha SIDEWINDER L TX GT (SW1NLGLR), search all our OEM Parts or call at 269-385-1540
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
There is a known issue with voltage regulators and draws. I've replaced a number of regulators that don't charge properly and have seen a voltage draw caused by the regulator as well. I'd stick OEM Yamaha if possible.
duhr8m
- Oct 27, 2007
- Minocqua WI
- sidewinder, SRXs, snow scoot + sport, vmaxs, enticers
The replacement regulator is now back to the ones used on the apexs and vectors, the newer sidewinder ones were made cheaper to save money but replacing them under warranty didn't seem to save anyone money, so back to the good ones. Another highly educated management decision with the same results that are putting them out of the SMB business.
- 8K
