bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Happens from sitting over summer in the humidity. I just put a thin layer of anti seize
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
So nothing to worry about... just grease them up and reinstall?Happens from sitting over summer in the humidity. I just put a thin layer of anti seize
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I would replace with new and keep them as a spare you have them out.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
No Grease... anti seize!So nothing to worry about... just grease them up and reinstall?
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I think he means the rust on the hex? I think that is odd, considering the coils seal up the holes.
And yes, just a tiny dab of anti-seize on those threads!
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
Yes... I was referring to the rust on the hex. I think the business end of the plugs look OK... a little black but that was probably from running the sled for only a few minutes to get it off the trailer and into the garage. The seals on the coils fit pretty tight, so I am not sure how enough water is getting in the holes to rust up the bolts on the plugs.I think he means the rust on the hex? I think that is odd, considering the coils seal up the holes.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Humidity over summer I will do it or if you ride and put it in a warm shop will do it too
87gtNOS
- Nov 30, 2005
- Toronto
hmmm, has your sled been sunk?
87gtNOS
- Nov 30, 2005
- Toronto
they look like they were soaking in water...
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
The sled has been over and through water, but never under it...
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Anti size on the threads and I put dielectric grease in and on the coil tubes.
87gtNOS
- Nov 30, 2005
- Toronto
dielectric grease does not conduct, so make sure none on the end of the plug (threaded cap)
vodoo child
- Oct 29, 2005
- Palmerton Pa.
Really, I've used it for many years on every plug and connection on all my vehicles, motorcycle's,trailer and sled and never had electrical problems.dielectric grease does not conduct, so make sure none on the end of the plug (threaded cap)
