rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
working on fords for 20 years ive seen the same in the plug holes on most cars even ones a few years old. rust,dust, corrosion etc. (the climate we all live in is way hot then way cold ,damp many months, its normal) as long as you got the plus out ,cleaned the holes and used a little dye electric grease on install its fine.
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- 2008 Yamaha Vector LTX GT.
- www. Moosehead Lawn Care.com
- YAHOO
- colemanbodemer@yahoo.com
Yep I hear you there, will be keeping an eye on it. I did not check/ or replace the plugs since I have owned it. I just decided it was time to replace them the other day, as I want to know they are brand new/ good. I bought this sled last February rode it for the rest of the season (put on about 1,600 miles). Just replacing them now. I have only put on about 30 miles this year. Thanks for the help on this guys.I would keep a eye on it. Possibly got packed with snow at some point by previous owner. Possibly been like this since you took ownership of sled.
Did you check or replace plugs after you purchased it?
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
I always use grease around the top part of the coil (the rubber plug, that keeps the water out) as putting them in with no grease is a pain to take them out down the road. Amazing what a little grease does to make removal that much easier the next time. As you can see I had all I could do to get the last one out (the one pictured above). The rubber plug on the one above was so stuck in the motor, I ripped it trying to get it out. On my vector I used grease when I changed the plugs on that, and it was a breeze being able to pull the coils out after that!! Thanks for the help!!working on fords for 20 years ive seen the same in the plug holes on most cars even ones a few years old. rust,dust, corrosion etc. (the climate we all live in is way hot then way cold ,damp many months, its normal) as long as you got the plus out ,cleaned the holes and used a little dye electric grease on install its fine.
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
yea im in the same boat but w two sleds. bought the skidoo 4 stroke in late feb . and the apex in august this year. had to go through both sleds entirely . real joy. lol next year i will spending way less cash to get them up to par. good luck and buy some moth ball packs and scatter them all over. youll see alot of threads w critter issues
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
I got the critter issues under control, lol. Used peppermint oil inside both my sleds this summer, never had anything get into them all summer long. First time I used peppermint oil, now I am going to keep using it, lol. I have been having mice issues every year, in years past, but this year with peppermint oil, was mint!! I dripped it on all the foam on the side panels/ by the clutches, nose cone, places like that. And it worked!!yea im in the same boat but w two sleds. bought the skidoo 4 stroke in late feb . and the apex in august this year. had to go through both sleds entirely . real joy. lol next year i will spending way less cash to get them up to par. good luck and buy some moth ball packs and scatter them all over. youll see alot of threads w critter issues
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
now you can say your sled is mint literally. lol,, never heard of using peppermint oil but i will try next. prob smells much better than moth balls
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
Yep true. My sled is running great btw, put dielectric grease on the coils/ down in by the spark plug to keep it from rusting farther. Put on 110 miles today, ran flawless!!now you can say your sled is mint literally. lol,, never heard of using peppermint oil but i will try next. prob smells much better than moth balls
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
Make sure you put the peppermint oil on both side panels, nose cone, and any where there is foam. The smell stays all summer long, worth it tho to not have mice issues. Plus it does not smell bad either.now you can say your sled is mint literally. lol,, never heard of using peppermint oil but i will try next. prob smells much better than moth balls
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I will have to try that this year, when changing the oil filter on my 09 it was packed full of pink insulation under my engine. What a PITA that was to clean out, luckily no gnawed wiring anywhere after looking very closely.
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
Same here I got sick of that crap to. Luckily they have never chewed any wires yet. At least the peppermint oil seems to do the job.I will have to try that this year, when changing the oil filter on my 09 it was packed full of pink insulation under my engine. What a PITA that was to clean out, luckily no gnawed wiring anywhere after looking very closely.
Where do you buy peppermint oil at.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Amazon, where else? Everything is on Amazon!Where do you buy peppermint oil at.
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
At the local natural foods store.Where do you buy peppermint oil at.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Dielectric grease is your friend. Been using that since my first rx. Never had an issue like that.
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- YAHOO
Yep. I have never had an issue like this before also, that is what you get for buying a used sled....Dielectric grease is your friend. Been using that since my first rx. Never had an issue like that.
