PIcked up an RX warrior with 58 miles on it. Sled threw a rod, and it messed up the cylinder pretty good. has anyone had an rx block replated? if so where could i get it done? thanks in advance for any help!
I read your other post and from the amount of damage you described I think you'll be better off finding a good used engine. But if you decide to fix it you can get the cylinder fixed at Millennium Technologies. They have to redo all the cylinders because it's a monoblock and that'll probably cost around $500 plus any extra work on the bad hole. If you need a piston i've got a stock one with 300 miles on it, Ken.
