SRXNOMO
Is there an easy / cost effective way to convert carb rx1 turbo to efi???? I dont have a real problem with the carbs and a/f ratio s on my rear mount kit 22psi, but always looking to upgrade. thanks Also does any one have the short 90* exhaust pipe for the left exit that would have been for my turbo. It has a muffler on it that exits out both original spots and the air filter is taking in hot air from under the seat instead of from the right side exhaust hole. Also looking for some better clutch parts, I have stock primary white blue white spring old style hc weights, stock secondary white spring bender helix set at 50*. Geared one taller on the top gear. Over revs all the time and doesnt seem to want to shift out. Any input on clutching / gearing combo would be nice. I got some things in mind but nothing for sure. Thanks
LightningPro
- Nov 13, 2004
- Traverse City Mi.
- lightningprollc.com
- 2011 Apex, 2006 Apex, 2004 RX Turbo
- Traverse City Mi
You might want to at least check this site to see what might be involved in the conversion. Hope this helps
http://roadstercycle.com/yamaha_vmax_fu ... cv_car.htm
OSP has complete systems for the RX1.
SRXNOMO
WOW!!!!!! OSP has some very nice looking stuff, however, it is a tad bit out of my price range. I had heard of guys installing R1 efi pieces on the RX~1. Thanks for the input.
Ski-Dooin' it
propane.. 10x as easy.. cheaper then race gas and simpler to tune then carbs.
SRXNOMO said:WOW!!!!!! OSP has some very nice looking stuff, however, it is a tad bit out of my price range. I had heard of guys installing R1 efi pieces on the RX~1. Thanks for the input.
It won't be cheap period. Need throttle bodies, new fuel system, coils, and EMS to run it all. You may be able to contact Paul at Impulse Turbo. He has a standalone EMS thats reasonably priced for Apex's and Nypex's that he builds. I would still guess you'd be around the $2500 range or more.
SRXNOMO
Kinda what I thought!! I have too much free time and my mind is just drifting around and coming up with ways for me to blow my money. LOL!
i have harness, ecu, and fuel rail throttle bodies from an r1 I will sell for 150 shipped from a project I never got around to, then the apexes came out.
SRXNOMO
BETHEVIPER said:i have harness, ecu, and fuel rail throttle bodies from an r1 I will sell for 150 shipped from a project I never got around to, then the apexes came out.
Will it for sure work on the RX~1? Has anyone done this conversion? This is what I am wondering
