rx1 fern
Good day everyone. What are some of your clutching setup for a midmount turbo running 25 psi boost . I have a stm rage 8 primary with stm weights and I'm running stock secondary with the white secondary spring . Just looking to see what I should run as far as a secondary spring and helix . Thanks for any advice .
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Had real good luck on snow with a purple EPI secondary spring and stock RX1 helix...
rx1 fern
Would you have a part number for spring by any chance. ThanksHad real good luck on snow with a purple EPI secondary spring and stock RX1 helix...
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
ACss5
rx1 fern
Why the artic cat purple instead of Yamaha . Thanks for the help also
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Works better
rx1 fern
Thanks for the help . Gonna order one . How come you run stock helix still . See lots of guys run a 50 helix with turbo sleds . Why is that . Thanks again
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
I actually run a Team Secondary on my trail turbo setup, but for snow drags at 25+ psi this secondary combo was always fastest.
rx1 fern
Sounds good and thanks . What was the settings you had for secondary spring . The wind . 3-3 or 6-1 . Thanks again for all the help.
jimmyhighway
- Feb 6, 2006
- Northwestern Ontario
- 13 Skidoo Freeride 137
11 Yamaha Nypex MCX
Purple EPI now has a Yamaha part number available (same spring). The Spring is offset different than Yamaha. I've run it at 0 & 1 with good results. Straight 51 dalton helix. Look forward to testing stock apex 51/43 as suggested above.
rx1 fern
You have a part number for this spring . ThanksPurple EPI now has a Yamaha part number available (same spring). The Spring is offset different than Yamaha. I've run it at 0 & 1 with good results. Straight 51 dalton helix. Look forward to testing stock apex 51/43 as suggested above.
jimmyhighway
- Feb 6, 2006
11 Yamaha Nypex MCX
EPI part #YDR10
rx1 fern
Th
thsnks . So what's the difference with each purple spring . Which one is better . Thanks for helpEPI part #YDR10
jimmyhighway
- Feb 6, 2006
11 Yamaha Nypex MCX
I was told by EPI they are identical springs only the part number is different. They use cat style indexing that's the reason for 0&1 wrap. Note they are Very stiff to compress during install.
rx1 fern
Cool thanks . My sled is an rx1 but same thing . Also doesn't the apex and rx1 have the same helix .
