Ive been running 2 of them for over 3 yrs never a problem. Over 10,000 miles on the one set.
homerj
find much difference when you installed the heel clicker kit?
Yes I did. When I made the change at first I had 2 RX's that were almost identical in every run regardless of drivers. I installed one kit on the 03 and immediately picked up 1 to 2 sled lengths over the stock one. I then installed overdrive sheaves on the primary and without changing gears picked up over 5 mph on gps on the top end and that sled would then walk away from the ohers and would even eat up Apex's on the top end. The shifts are so hard under WOT that you can feel the cluthes shift out. at 70 you can let off and then punch it and the sled lifts the skis out to just shy of 100.
homerj
good stuff, worth the investment then
- 7K
