alexyamrx1
hello i have a problem with my rx1 i have put a piston 10:1 compression and my rx1 its hard to start what is de strating jet sise i need...thanks
bdm
alexyamrx1
bonjour jai un probleme avec mon rx1 jai instaler des piston 10:1 de compression et mon moteur ais dur a décoler (trop de gas)je voudrais savoir quelle grosseur de jet de démarage je pourais instaler merci a tous
wienerwater
Yea, I had the same problem, until I put the battery back in and it fired right up and starts ever since.Sometimes, it can also be the wrong colored anti-freeze you are using.
