RX-1 Oil Pressure
Bob Miller
New Milford CT
Present Sled: 2011 Yamaha Apex 128
The service manual states that after an oil change , to remove the oil gallery bolt to check for all pressure. Does anybody do this? Is this really necessary? Where is that bolt located? On the exhaust side of the head on the clutch side? :roll:
I highly doubt any one does this and the dealers dont eather!!
WHY and to time consuming!!
I have seen problems on automotive applications, usually when installing a rebuilt engine. We always prime the oil system by hand, sometimes having to pack grease in the oil pump to get it to pick up. The system is very dry at this point, of course.
Parallel this to draining your oil with the engine hot. Hot oil would drain more completely out of everywhere. Then, when refilled, the oil pump could have a problem picking up the oil.
So, I believe Yamaha is just giving us a fail-safe method of making damn sure there is oil pressure before heading out & ruining the engine.
Just my 2 cents, from an auto repair shop point of view, on this question.
Good feedback tembro! :D Do you know where that oil gallery bolt is located? :roll:
If you have the full manual, the picture & description is on page 2-24. I tried to attach it out of a pdf file, but I'm not smart enough to do that...yet!
Basically, it's the oil gallery bolt just to the left of the left-most (is that a word?) exhaust flange. You crack it loose, fire up the engine to bleed out the air & making sure oil seeps out, then tighten it...you're done.
Nice showing RX Warrior 8)
note
bikes dont have oil psi gauges. allso you have realize that that oil gallery is under the ex heat shelding and would hard to get to let alone run a wire or line from or to
I don't do the galley bolt, but when I add the 3qts, run it and add .2-.25 more oil to get it back to the same level, I figure I am pretty safe on the oil circulation department :wink:
oil psi
i will second that. no bone ratlling oil psi is got to be good. drive it like you stole it :twisted:
