RX-1 Stage 1 MPI Supercharger
obr
Alta, Norway
Website
www.techservices.no
Anyone know what the stock pulleys on the stage 1 is? I've got 4 pulleys in my kit, but not sure wich ones are the correct to use.
Also, what kind of jetting are you running, and at what elevation?
Need to know how much boost you want to run to tell you which pulleys to use. 5 lbs, 7 lbs, or 10 lbs?
Big pulley on the crank - small pulley on the charger = big boost
Small pulley on the crank - big pulley on the charger = small boost
Equal pulley on both = medium boost
Jetting? 130 mains and 17.5 pilots @ 500-1500 ft - good starting points
Good luck!
