obr
- Aug 16, 2005
- Alta, Norway
- www.techservices.no
Anyone know what the stock pulleys on the stage 1 is? I've got 4 pulleys in my kit, but not sure wich ones are the correct to use.
Also, what kind of jetting are you running, and at what elevation?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Need to know how much boost you want to run to tell you which pulleys to use. 5 lbs, 7 lbs, or 10 lbs?
obr
- Aug 16, 2005
- Alta, Norway
I think I'll be able to run 10 on premium with low comp pistons. I think two of the pulleys I got is for the stage 2.
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
Big pulley on the crank - small pulley on the charger = big boost
Small pulley on the crank - big pulley on the charger = small boost
Equal pulley on both = medium boost
Jetting? 130 mains and 17.5 pilots @ 500-1500 ft - good starting points
Good luck!
Good luck!
