matt335
- Apr 19, 2025
- Chicago
- YamahaRx1
Hey everyone. I’m planning tu built RX1 turbo. Max 8 psi. I need some advice about fuel delivery, bowl vents tube, overflow lines.
I saw some setups with overflow lines connected to charge pipe, but some of them not. What’s the difference?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
There's some good information in these MPI instructions (as well as pictures). It's talking about supercharger, but boost is boost. You need to boost reference the bowl vent tubes & the slide tubes as well so everything works properly.
https://www.mountainperformance.com...rx1 install rev 3 with pics-update11-1-05.pdf
matt335
- Apr 19, 2025
- Chicago
- YamahaRx1
Thanks!There's some good information in these MPI instructions (as well as pictures). It's talking about supercharger, but boost is boost. You need to boost reference the bowl vent tubes & the slide tubes as well so everything works properly.
https://www.mountainperformance.com/Files/Download/msc-1000 supercharger rx1 install rev 3 with pics-update11-1-05.pdf
