Him
- Mar 10, 2004
- Sweden, the northern coast...
- Sweden
- Apex -11 MCX290
RX Warrior -04
Have anyone any clue on this, it began after the 800km maintance.
The machine splutters and misfires from 6000rpm up to about 8000rpms with a really bad performance, no warninglamps is on and the machine is varm and fine. And the misfires is increasing.
If I use the choke a bit the power kicks in and the misfires lessens. My dealer thinks it's the airscrews and refuses to check anything else
Sparkplugs is changed, airscrews checked and they are 2 turns out, it's tested on opening the screws to 3 turns and the machines still misfires, a little less tho.
Silverbullet
After my first service the dealer install the air box wrong (it wasn't sealed to the carbs correctly) made it run poorly.
Him
- Mar 10, 2004
- Sweden
- Apex -11 MCX290
RX Warrior -04
That is not the problem. The airbox has been out atleast 10 times as they have tried to adjust the airscrew... They don't give up on the airscrew. I guess they still think that the RX is a 2-stroker...
Any other ideas?
Any other ideas?
LazyBastard
Tell your dealer to FIX IT, it is their responsibility since its still under warranty. If they refuse, call Yamaha, complain, and find a better dealer.
It could be the wires in the nose under the beer can holder - make sure that none of the wires have broken insulation.
Him
- Mar 10, 2004
- Sweden
- Apex -11 MCX290
RX Warrior -04
I'm going to check the cables. Thanks..
They wont refuse on fixing it, It's just that I don't think they have the knowledge, so it's gonna take a while and meantime I'm looking for answer other than those the dealer tells me, and this site seems to be the best one to choose
And hopefully someone has a couple of ideas that I can force them to try..
Just so I have a chance on riding this weekend... The wheather outside is -2 degrees C and sunny....
Did you try bypassing the T.O.R.S.?
Him
- Mar 10, 2004
- Sweden
- Apex -11 MCX290
RX Warrior -04
Perhaps a silly question, but how do I bypass it correctly?
I've never had any need on doing that on any machine I own earlier.
POWERHAULIC
There is a two wire connector coming across the tops of the carbs, with 2-bullet connectors in it. disconnect it and connect the ends going in the sled harness.
I would suspect possibly plugged pilot jets, from what you describe tho.
LazyBastard
If it was tors, it wouldn't make it to that high of RPM. Only would make about 4000.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
My guess is dirty or clogged pilot jets. Have seen that a couple times. If a few of them gets clogged carbs gets out of sync. A friend of mine had his pilots clogged as much as 3 times on the same day, so check it out. His sled acted just as you describe.
kmer
Check that your cables are sitting properly in their place at the throttle lever end. Mine was out and would activate the tors.
Him
- Mar 10, 2004
- Sweden
- Apex -11 MCX290
RX Warrior -04
Thanks for all the tips. I'm on my way to the dealer to have a couple of words with him, just to talk him into the right way
Him
- Mar 10, 2004
- Sweden
- Apex -11 MCX290
RX Warrior -04
It was some dirty jets, so now it's running like a dream. Thank you all for the help. Now I must test it a bit more.... -4 degrees C and sunny...
