cadiyama
Need some help here guys.
The 03 RX1 came with a 121" cone type track.
This sled was converted to a 136" with a 1.25" ripsaw.
The problem is that with the extra load on the engine, I'm only
turning about 9600 to 9800 rpms.
What's the best way to get this combo up around 10200 to 10500?
grader
assuming the clutches are stock, switch the primary spring to a yamaha orange-silver-orange. this has a higher total force for shift out and should get you close. also check center to center and offset, and adjust if needed. also remove stick coils and clean plug contact area with brake or carb cleaner to remove carbon dust. theres more that can be done, but this will put you in the right direction.
JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
Change upper gear to a 23 tooth gear. Will put less load on the engine due to the biggger track.
stock is 24
stock is 24
RX-Dave
- Nov 14, 2004
You can run 24t on top, but you need to clutch for it.
I am running a 1.375 x 136" Cat SnoPro Track with stock gearing. Clips 121-123 on the dream meter.
You just have to change the secondary setup. Run a warrior secondary spring and a Dalton 47/41 "R" helix and be happy
This will change the amount of torque seen by the motor. Also check the coils and plugs just like Grader mentioned
cadiyama
What about clutch arms?
Heel clickers, heavy hitters, or removing tip weight on stock arms.
Any ideas here?
Any ideas here?
black john
stk arms work
stk arms work
RX-Dave
- Nov 14, 2004
The stock arms will work fine with that setup in the back.
Me, I am running a GRN/GRN/GRN with Dalton DPYR weights loaded right up and love it.
black john
arm,s
that should still work no to bad. those are realy niice arm,s to work with.
