Yea ok! lol I guess I would need a rack of carbs which I dont, I am trying to save the guy the trouble of not possibly having to take the carbs off to clean and I can see this product working.
smooch
- Jan 16, 2012
Mighty said:The guy wants to ride now. Send him a good set of carbs, have him send you his and you can experiment.........Sled Dog said:Maybe it will we wont know until we try it and put it to the test.
Thank you. I am interested in riding and not being a experiment. Taking apart the carburators and cleaning them is not really a problem, what should i be looking for when i take them apart? thanks for the replys
I am sure Mighty will help you to the end of your carb cleaning. I was trying to prevent you from having to do that.
smooch
- Jan 16, 2012
No offence, thanks for the suggestion. I would try it but its not available in my town so i can not try it out. What do i look for when i take the carbs apart?
Indy
check the tech section for complete instructions. try using the search.
smooch
- Jan 16, 2012
OK. I found it. Seems to be very detail. even a dummy should be able to do it.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The toughest part will be getting those damn float bowl screws out. Make sure you use the proper fitting screwdriver; JIS.smooch said:OK. I found it. Seems to be very detail. even a dummy should be able to do it.![]()
Indy
OK, once you've done it a few times it will become 2nd nature. Welcome to the RX1.
