Just installed ECP kit and was running fine. On the stand that is as we have no snow. It seemed real responsive and no burble at all. A few days later went to take it out of the garage to put on the trailer and it was breaking up bad when it needed the power to move the sled. Plugs are definitly OK. What should I look for. Thanks
thinksnow
TORS
Is it the TORS? Not sure why it would work on the stand and not on the ground though. Unless you have a strange pull on the throttle cable that is causing it to engage.
Lance
Lance
running rough
Definitly not the TORS. I will be taking the carbs back off to make sure the pilots didn't pick up some dirt. It idles perfect just when you give the gas it breaks up.
You have to sync the carbs it will not run good until it is done. I am sure the ECP filter plans say that also. You need a tool called a manometer to sync them properly.
