yamaha-rider
does any one know where i could find a set? i have been trying to find some and have had no luck
SHodas
GUKROKIT
You could save a buck if you put the kit together yourself.The k+n site has part#RU-4720 for about 50$ each.These are the hauck ones(raptor style)I experienced no top end loss with this style vs the other style from ecp that most on here are running.No velocity rings are necessary with this style.Pre filters at outerwears part#20-1568 for 16$ each.The k+n drychargers are 35$each if you want theirs.Then just get 160-165 mains,20-22 pilots and some holtzman springs from them or used on here.I'm running the red ones with no issues.Others are running silver or blue ones.Over 300$ is a little steep for this stuff imo.
bedwet
try hauck powersports they have some used ones on there site and new ones
yamaha-rider
ok thanks for the help
maxdlx
Look up sled dog air box mod. I have run both, and his mod works just as well, ni icing issues less money way less noise, and fuel milage back to stock or better. Maxdlx
RXMax
yamaha-rider
now what does the carb springs for,i am guessing better throttle response,and also what does the diffrent colors mean??????
