Does anyone know if a 08 Nytro RTX rear suspension will bolt right into my 05 RX1 with NO modifications
mbarclay
i doubt it would just bolt in without modifications but im not 100% sure
kinger
It will NOT bolt in with NO modifications.
It WILL bolt in if your willing to drill a new mounting hole.
sledhead_dan
I installed a 153" 07 nytro susp in my 151" 04 mtn rx1. front hole moved forward to next rivet, approx 1 ", made new rear brackets out of alum and drilled new holes, not sure where they compare to original holes but I could measure center to center where they are now. I also run an offset axle with big wheel kit to run the 151 for now.
