ps4020
I just installed my m10 in my 04 rx1 set up per book, tested out use to be able to lift skis can't anymore (would like to) is this nornal for the m10's or can I adjust the straps and if so what holes?
Birdman
M10's rides great but doesn't transfer weight well.
Seems that everything is a compramise with a sled.
How you can adjust the weight transfer is shaving some plastic off the bottom of the sliding blocks (rear arm) . I think that you can also buy pre-cut blocks from Fast and get some advise on set-up as
well
Good luck, With some adjustment you can get a good all around set up
well
zelinsmrx1
- Feb 10, 2004
- New Baltimore, MI
- 2017 Yamaha Sidewinder
If you want to do wheelies buy the green kind of sled. I've had an M-10 in my '03 after the first season and now have 8300 miles on the sled. If any sled is set up right you should not get any wheelies unless you are running something crazy like the one guy putting 380 hp in an rx-1. It's hard to avoid trees with the skis off the ground.
just my .02
just my .02
