brs077
- Mar 8, 2005
- Cobleskill, NY
- 2013 Yamaha FX Nytro XTX 1.75
Hey all,
I've got an RX Warrior LE, as the subject states. It's only got 500 miles on it, light season last year and horrid season this year.
In january, it wouldn't start at all, battery was dead. By the time i got it replaced, the snow we had was gone. When i was replacing the battery I noticed one of the carbs was completely off of the cyl. I doubt it ran much like this as that would cook a piston pretty quickly, but it may have been run like that briefly when moving the sled around the yard.
I started it up and ran it around a bit and it seemed fine, but due to the lack of snow, I couldn't put any decent mileage on it. Yesterday I ran it about 80 miles, It would not idle, it would shut off. At mid throttle it would pop and mildly backfire on occasion. (Brand new plugs by the way, i changed them when I changed the battery) I pulled 2 of the plugs, and one had a light tan coating on it, the other had a thick coating of tan powder on it (the one that the carb wasn't hooked up to).
I'm pretty sure I need to change the plugs again, but outside of that, does anyone have any suggestions as to where to look?
The gas in the sled is old, from last year. I added half a tank of good gas to it, and it seemed to run a bit better. Should I try putting fuel stabilizer in it? Could the carbs be out of sync? or is there something more serious going on.
Also, I need to use the change the oil, can someone give me a quick overview of how to get to things and what tools I'll need?
