s/c nytro clutch help
extreman1
copenhagen,ny
what would u suggest for the secondary stock clutch set up for snow drags? also should I put the weight in the tips on primary? I have D&d magnetic weights it will pull the rpm with weight in tips. if I take the weight out of the heel and middle will that allow quicker acceleration? I am running 10 lbs boost
