extreman1
whats a good drag race set up for a nitro xtx s/c 10 lbs boost, its a snow drag. I have D&D magnetic weights. stock secondary. should I put all the weight on the tips? and should I change the secondary spring position? it will hold the rpms with the magnets in the tips only. but I havnt tried to change rear spring position
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Bump the secondary helix to straight 47 tune secondary with spring tension (60-80deg) based on traction needs then work on rpm by tuning primary.
