Schmidt Brothers Stage 1 and 2 Clutch Kits
torszula
Naperville, IL
does anyone have an opinion on the Schmidt Brothers stage 1 or 2 clutch kit? I' looking to take some of that hole shot feeling from the 08 Nytro and hopefuly achieve a smoother acceleration at a lower rpm. Is there another clutch kit out there that may be better?
Also, how much of a difference does the Sticky Fox Float shock fix work? If I were to have to choose between fixing the front shocks or the center which would be better. I really can't afford to do both right now so I figured I wouold do it in stages if it is really going to be a difference maker.
Torszula - The stage II clutch kit will substantially improve your low end engagement and mid range speeds. When you are at a stop and you gradually press the throttle, the sled moves forward very smoothly. If you pin the throttle, their stage II helix will get you going way better than the stock set up. I'm very glad that I got their kit. Check out youtube and watch their nytro dual exhaust 2 video. ;)!
hey nor'eastrner,
I just bought a pair of tghe Curve ski's w the LE up at Hay Days so my setup is very similar to yours. What do you think of the ski's?
nor'easter said:
Torszula - The stage II clutch kit will substantially improve your low end engagement and mid range speeds. When you are at a stop and you gradually press the throttle, the sled moves for very smoothly. If you pin the throttle, their stage II helix will get you going way better than the stock set up. I'm very glad that I got their kit. Check out youtube and watch their nytro dual exhaust 2 video. ;)!
X2 I love it and their service!!!!!!!!!!!!
:yam:
torszula said:
hey nor'eastrner,
I just bought a pair of the Curve ski's w the LE up at Hay Days so my setup is very similar to yours. What do you think of the ski's?
Torszula, I like my Curve skis. But I'll like them even more now that my alignment is correct. I also switched to 6" carbides. I rode with Nick on a TY ride, and he offered to demonstrate and set up my alignment a few months back. It may take me a while to catch up on some things, but I am able to make improvements each year.
